NyTrOMaNIaC
You can adjust the width of your ski stance, probably an extra 2 inches wider or narrower overall to give you better feel in the turns. I received a pm from a guy who was asking about it, so I thought I might put up a post to inform those who might not be aware. If you want a wider stance, all you have to do is remove your skis, and place the stock spacers (that the bolts go through) on the outside of each spindle instead of one on each side, and reassemble. You'll know you got it right when the ski saddle is closer to the inside of the spindle. Just do the opposite for narrower positioning (spacers on the inside of the spindle). If anyone is still unsure of how it's done, I'll take some pics.
