found 4 mph/still need 25 tooth gear
dracutaco
dracut ma/bethlehem nh(weekends)
this may sound alittle strange but i set up the radar run the same as last 2 weeks. i have a 05 rx1er with team clutching only,no other mods. i have 2500 miles on the machine and have had to replace hyfax twice. i purchased the oversize wheel kit and added one set of wheels near the rear of the machine trying to eliminate hyfax wear. the result was 4 mph 112mph top speed now!, anyone have any comments?
conditions change?
i hear what you saying LB but this was on a icy run area almost no snow and i have been running this area for about 3 weeks and have consistantly run 107,108 mph. suddenly 112mph, The other thing is if the hyfax are wearing that much there has to be drag. but that;s for the input.
Better air quality(higher atmospheric pressure) will give you a lot better performance.
could be that you have less drag...they say that also when you add graphite hyfax it can add as much as 3-4mph top end..
I just bought some and it even feels more slippery than standard hyfax.
Save your money. A stock Rx doesn't have the power to pull it. Now a turbo.............. well the 25 is not enough.
Mine has 1300 miles on it, and pulls 113 with stock gears, original hyfax (still in excellent shape) and no extra wheels.
I would like to see what kind of MPH you could pull with a 25???
Skydog
speed
119.2 mph stk gearing no over drive. just clutching and jetting. (dolton clutching) i dont think a 25 tooth will help you that much. do some jetting and clutching ;)!
