Found a potential problem /Quick fix
mainecabin
PA
Website
www.mainecabin.com
I am getting my Vector ER ready for the long summer nap. I took the plastic fairing off to the right of the gas tank where the reverse handle is. Once removed you will find the back-up alarm and other electrical components. The main wire harness comes down along the gas tank. At the top of the foot well the metal bends over toward the components and is relatively sharp. I found the wire harness was rubbing on that. Not close to causing a problem but down the road (trail) it could potentially rub through. I took a plastic tie and pulled it away from the sharp edge. Just thought I would pass it on to others.
Thanks for the info! I'll definately be checking mine.
