Fox Float 1 shocks 07 Apex RTX
1litre
Crystal Falls, MI
I own a 07 Apex RTX with the Fox Float 1 factory yamaha shocks. I am looking to soften the stutter bumps and utilize the suspension travel. The front suspension at 50lbs pressure in them doesn't seem to use much of its travel. Ski lift eliminated and arms are parallel. However the sled has a lot firmer but harsher ride than I like. Here are the options I am thinking of and would appreciate some feedback and experiences:
1. Rebuild and revalve.
2. After revalve add Hygear adjustable reservoirs.
3. Upgrade to Evol kit with original shocks.
4. Replace with Fox Float 2 and Hygear or EVOL reservoir.
5. Upgrade to Evol R Fox Floats.
Float X's are out of my budget.
Thanks for any advice and experience.
I have the same sled, I added the Hygear res kit and have been very happy with them. It did just as you are looking to do.
Rich.
I would say you are in need of a revalve. I had the air rese's on my 06' and while it did allow me to run higher pressures while still maintaining a lower rise in spring rate, I had no issues with the original "firmness" of the shocks. If you are at 50 psi and still feel the shocks are too firm you will need to revalve. The air is the spring and the valving is the bump absorption system. Since you already revalved your rear shocks I would now valve the fronts. The air rese's may be an option later to further enhance your suspension but I think it will only add confusion to the real issue at this point. Since you can buy them and add them at any time (no rebuild needed). Another option would be to add clicker rese's and get the Float X functionality. This would allow you to dial in the compression you desire based on trail conditions. If money permitted, I would go this route, and it doesn't have to be dual speed clickers either, singles will provide you with enough to get what you are looking for.
