Berg570
I bought some used Fox shocks for my sled. I read about air pressure settings for the bumps on the trails, but what should a guy run them at for mountain riding/carving up meadows?
I'm 180 lbs, lets say 200 or so fully geared up? Intermediate rider, I guess?
Pretty excited to put these on, you all sure make them sound sweet!
doober
Im about the same size as you, i do boondocking, and i like mine set about 100-110 lbs
SXlover
Do you still have the sway bar on your sled? If so I would recommend taking it off. At least that's how I ride my Apex with Fox shocks. I can't remember for sure but I believe I run about 90 psi, but I'm running Simmons Gen II skis with the Carl's cut. I'm 210 lbs before gear.
Berg570
Yes I have taken the sway bar off. I will start with 90 psi then, and work my way up from there.
Thanks for the reply's guys. I just mounted them today. They sure look cool
