fox float to apex xtx 2011
NORWAY
do you now where to buy fox float to the frontsuspension to my apex xtx.
want these with piggyback, thanks for answer
I bet eye to eye domensions are the same as the '06 - '10 Apex's front shock, so I bet you could use the Fox Floats made for those years Apex's......
The Floats with piggy backs are the Float X's and the Float X Evols.....
mclarenyamaha said:
i want some with piggyback, like the fox float x or the evol
Call Mike Carver at Carver Performance. He will set up a pair that will fit your machine exactly. He will also revalve them with a set up for your riding. Amongst other type of shocks, he is also a Fox specialist.
How about a float or coil spring conversion for the rear suspension?
That's what I just asked in a different thread.... Can the XTX skid be redone with Float shocks replacing the stock KYB coil overs?
