BordnBill
I'm sure this has been covered before, and I did do a search, but I came up empty handed. I just got some Fox Floats with Fett Bros. Canisters. What is a good air pressure starting point? Thanks.
bholmlate
I know that the yamaha '08 maunal suggests starting at 75 PSI for the front Fox float shocks for the Nytro MTX. I have run mine as low as 50 and as high as 80 just to see how it handled. I found if I had too much it made the sled feel really tippy to me and if i ran them too soft it felt really unresponsive to rider imput. I run mine currently around 65 PSI and have the original Fox float shocks with no sway bar.
It matters if you are running the Fox Float and Float 2 shocks because the Float 2 has a different valve stack inside.
BordnBill
bholmlate said:I know that the yamaha '08 maunal suggests starting at 75 PSI for the front Fox float shocks for the Nytro MTX. I have run mine as low as 50 and as high as 80 just to see how it handled. I found if I had too much it made the sled feel really tippy to me and if i ran them too soft it felt really unresponsive to rider imput. I run mine currently around 65 PSI and have the original Fox float shocks with no sway bar.
Thanks. I will probably start it at 65PSI then. I have the original Fox Floats with Fett Bros. Canisters and no sway bar. How do you like your Floats? Lots of conflicting opinions about them.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
I run mine at 65psi also. I've tried between 55 and 80 and I noticed that with to low of pressure it will side hill easier but handles like I'm riding on top of a beach ball! With the higher pressures the handling is more stable, but is harder to side hill. Also the ride is a little stiffer up front.
Bill
Bill
bholmlate
Hey Mtnviper
I think your description was a lot better then mine. The beach ball was a perfect analogy for too low of a pressure in the shock That is exactly what it felt like to me as well. These shocks are pretty sensitive to changes in air pressure.
BordnBill
Right now, I went with 75 psi since I have the canisters on there. Seems like I got a lot of sag when I lowered my sled down off the jack though. Sagged about 1.5"-2". I think it did the same with the stock shocks, but don't remember.
