snow11
- Feb 17, 2014
- Skowhegan Maine
- 2007 yamaha apex
Hi All
Can someone tell me if fox floats off a 09 nytro will fit a 07 fx
And are they any good or should I just have the shocks rebuilt on the FX
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
nope, 1.5" longer and the float 1 aren't a very good shock. If you look around you will find places clearancing Float 2 shocks for 450-550$ a pair and they are a big improvement over float 1 shocks.
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
If you are looking for a cheap pair of Floats that bolt on, search for a set from an Apex. They are really close to the stock length Phazer shocks.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
One other thing about the floats that needs to be considered that not many people mention is the bushing mounting points. Yamaha cheaped out on the oem versions of the float and used a polyurethane bushing and collar instead of the more expensive and durable rod end style that come on the aftermarket versions of the float. The oem bushing ovals out after a year or 2 of hard use which allows the shock to move up and down in the mount. I discovered this 2 years ago on my son's 09 RTX.
Long story short, buy the aftermarket versions if you have a choice. And as already mentioned go with the float 2's over the original floats.
