Fox
RJH
Muskoka
Lot of guys asking about Fox..so here is the deal..
You need to set the shocks outside and acclimated to the cold weather as pressure will change with temperature.
You need to lift the skis off the ground to pressure up .....the shocks cannot be resting on the ground.
If both chambers are empty..(I would recommend you do that to start) you have to charge the Evol chamber first.then the main....this will set the piston in the middle
You charge the Evol for max hard bumps..if you bottom..more pressure.
You charge the main for ride height and body roll...
Our sno -x sled had 98 and 220 depending...but that is huge pounding
Talk about clickers later..
