pat the rat
- Mar 13, 2006
loving my new venture,the only thing is when i shift in reverse and give it gas,all the freeplay comes back and makes a loud ''clunck''same when i shift to forward,my vector never does that and it has the same freeplay,is there a fix for that or is it something i have to live with,i know that if you feather the throttle,it doesnt clunck as bad but its kind of a pain
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
I THINK that you will find that your reverse linkage is slightly out of adjustment. The adjustment is so fine that a half turn on the linkage makes a big difference. Had the same problem on my Vector after I changed out the case bearings. Check your measurements VERY carefully.....or have your dealer do it if you're under warranty.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Also check your chain tension....finger tight, then back off 1/4 turn.
Muskoka Man
not sure if there the same or not, my 09 venture Gt had it to , you get use to riding it soon and dont really notice after awhile
XTC500
Even without using reverse, just throttling on/off & back on the gas, i find the Vector has a lot of backlash in the drive system. I've confirmed the chain tension is OK, so the backlash must be in the gears.
pat the rat
- Mar 13, 2006
the chain tension is ok,i tried adjusting the reverse linkage,it is right on spec as per the manual,might have to call the dealer
Muskoka Man
no more yammie dealer in elk lake Pat?
pat the rat
- Mar 13, 2006
he moved to new liskeard,but i bought the sled in béarn,quebec,this is one of the best yammy dealer in the region for service and price,they had a 2013 for much cheaper than any 2014 and its the same sled except for the skis
canadianhunter
With our Rage's I noticed a change in the clunk when I changed belts. Some belts had a little bit more tension on the shaft of the primary which possibly took up the slack on it's own before I applied throttle to move.
pat the rat
- Mar 13, 2006
I have over 300 km now and it doesnt clunk as much now,i guess i'm getting used to it
