Frogzskin for air box
gytrapex
Age
37
06 yamhah apex gt
When I got my sled It hade a hole in my air box for a mod I was told on here to cover the hole up with frogzskin but here my prob they don't make one the size that I neeed what could I do to make it work
If the hole is on the bottom of the airbox I wouldn't worry about it. Just make sure there isn't alot of loose dirt/debris in the engine compartment, and it should be fine.
It is at the bottom
If you still have the factory screen and/or foam piece below the airbox lid, you're good to go. The only thing the airbox mod does is enlarge the original opening in the bottom of the airbox. You simply cut the horn off that sticks down in the same location, which leaves a larger opening, and there isn't anything over it from the factory.
Keep in mind that sleds don't usually see the dirt and debris that other ATV's do, so as long as you don't have a bunch of loose crap built up in there from trailering on salty roads, summer grass drags, etc , you're fine as is.
This is what I did to it
