ShootToThrill
Has anyone installed 1.450 woodys in their nytro and had the track ratchet then check for marks or holes in the front exchanger? I want to use a long of a stud as possible. Any feedback on this is appreciated.
ShootToThrill
I can't believe no one has put in 1.450 studs.
kingedwards99
I put 96 1.52s redtips on my sled, and they work well!
skyboz
I have 1.375's and about one inch above the heat exchanger, the studs have clipped the flat metal strip up there from ratcheting!!!
ride -4-fun
i have 1.325 144 down the middle and noticed same thing ,metal above cooling being hit
Yamahnator
skyboz said:I have 1.375's and about one inch above the heat exchanger, the studs have clipped the flat metal strip up there from ratcheting!!!
Same... So make sure that track stays adjusted.
ShootToThrill
Thanks for the input. I'll keep an eye on the track tension for sure.
- 8K
