Front heat exchanger and studs
ShootToThrill
Northeast lower Mi.
Has anyone installed 1.450 woodys in their nytro and had the track ratchet then check for marks or holes in the front exchanger? I want to use a long of a stud as possible. Any feedback on this is appreciated.
I have 1.375's and about one inch above the heat exchanger, the studs have clipped the flat metal strip up there from ratcheting!!!
Same... So make sure that track stays adjusted.
