yamaha06
So I am in the middle of swapping out my track and was inspecting the tunnel, noticed a slight gap between the top of the front heat exchanger and where it rivets to the tunnel. I had a couple louvers bent and straightened them up, but I noticed those upper heat exchanger rivets are loose. It looks like it’s probably going to be a pain to replace those rivets, would it be a bad idea to rivet from the inner tunnel up? Or what about using small nut and bolts? I didn’t really want to get into removing the tank and headed etc. From the looks it’s probably been like this a while.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I had the same issue and I used 1/4 inch nuts/bolts and fender washers. The exhaust manifold needed to be removed in my case.
DMCTurbo
- Nov 12, 2005
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Had the same issue. Went at my tunnel from the top - but its a lot of work. I ended up drilling one or two more holes into the exchanger to add rivets.
Its pretty lightly built, thats for sure.
MS
MS
