FRONT W ARM
JERSEYJOE
KEARNY, NEW JERSEY
I HAVE HEARD THAT THE 2010 FRONT MONO SHOCK SKID W ARM IS A LOT BEEFIER THAN THE 2006. IS IT A DIRECT BOLT IN? IS THE REAR ALSO A BEEFIER DESIGN AND A BOLT IN?
ARE THESE 2010 PARTS AVAILABLE YET?
well yes and no...
the 2010 is beefier then 06....however it will not fit as the 2010 is the mono 2 skid which is alot different overall.
you COULD buy a 09 front arm,which WILL FIT your 06 directly....the 09 arm is also beefed up bigtime(like the 2010).
the rear arms I believe had very little problems and havent changed much at all.
most of us here,have contacted a member(welterracer) and sent out arms to him for 199 dollars and he BEEFS them up like a new 09 design,and also that included powdercoat to look NEW!...A much better and cheaper way to fix your problem...this is less then the single cost of a new front arm alone!
here is mine after i got it back from Brian.
BEFORE
AFTER
My fix for the shock rub
check out my entire gallery of SKID PICS & fixes here:
http://www.moviephotoforums.com/photopo ... hp?cat=717
Dan
