Crazydiamond
- Nov 15, 2012
- Appleton, WI
- 2011 Apex SE, 2007 Phazer
Sunday morning the temp was -16F and my 07 Phazer would turn over fine but not start. I finally realized that i wasn't hearing the fuel pump prime when I turned the key to the first position. I pulled the side cover off and warmed up the relays in front of the battery with my bare hands for a few minutes and the fuel pump kicked on and sled started right up. Is there a better replacement relay? Also, which relay is it? If I have to pull it out I would like to know which one it is so I don't remove the wrong one.
