fuel pump relay
ApexDriller
Northern SK
Anybody got the part number for new updated fuel pump relay, Ive had it with the original one freezing up and having to thaw it out, 3 times today at least.
New for 2011 there is a new relay and holder for the relay recommended to be used for this issue. The new relay is part number 8HG-81951-00-00 ($7.76) and the holder is 8HG-81952-00-00 ($2.12). This relay will work on all 06-10 fuel injected models.
BOUNTYHUNTER said:
Try pounding it real hard on something firm to break up the carbon inside, I did that on my attak and it never happened again after I did that.
Yes I tried this, as it happened again last night and instead of thawing out relay I whacked it a few times against the tunnel. Fuel pump fired up immediately. Thanks for the tip bountyhunter.
Which relay is the the fuel pump? Just wanted to keep this in mind for any future probs. Thanks
It is one of the 3 out of 4 that look the same. They are located in front of your left knee when riding. Mine was the one closest to the fuel tank (#4). But sometimes they are different order.
Thanks!
