Fuel System wiring on a Bender kit.
Skydog
Byron, IL
I have both grounds hooked to the neg on the battery. The orange wire with the fuse block in it hook to the + block labeled B. Now all i have left is one hot wire to switch the relay. But the manuel say single brown wire run up to the right side of handle bar loop??? I dont have a Brown wire??
Then it says fuse block above chaincase attach brown wire to blue/white wire under fuse block??? What am i missing guys?? That blue/white wire is not hot when key is on?? So if i did run my last and only wire to the blue/white it does not have power to switch the relay.
Skydog
