Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
Anyome run the stage one kit or any kit from full power performance? For an apex. How well build are the kits? reliable? Spool fast?
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
I can add that I've had FPP kits, in some form, for many years now. Started out with a base stage1 Apex kit, which has of course evolved over the years to what I have now.
Their Apex kits are great for what they are intended for, trail riding many miles. That kit design has literally been around since the Apex first got released by Yamaha, so proven and refined over it's lifetime. It's design is very similar to the MCX (with tunnel snow cooler and front intercooler) with the exception FPP uses a simpler piggyback fuel controller.
They do spool fast, depending on your interpretation of "spool fast", but they will respond fast enough to not be able to get the power to the snow if you are too aggressive with clutching... They do have a real good clutch kit to match. I think there are a few FPP kits running around the rock in your neck of the woods.
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
I was thinking of putting it on my MTX, because I do trial ride and so spend alot of time in the hills but I didn't want anything over 230 hp as it would be to much for my rising skill, as this is the first year on my apex.
youngsterx1
- Jan 3, 2005
- Manitoba
- Apex
Hi I purchased the Bender Turbo from Yamaha for my 06 Apex when it first came out. I have put 5000 K on it now. It has worked good over the years and I am quite happy with it. It is a great trail turbo. I usually run at about 200 hp or 9lbs of boost. I have had a few hiccups over the years which required some attention but generally happy with it. It will do an honest 120 mph everyday easy.
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
Good to hear but bender doesnt make turbos anymore ? And that's what in looking for something in that power rangeHi I purchased the Bender Turbo from Yamaha for my 06 Apex when it first came out. I have put 5000 K on it now. It has worked good over the years and I am quite happy with it. It is a great trail turbo. I usually run at about 200 hp or 9lbs of boost. I have had a few hiccups over the years which required some attention but generally happy with it. It will do an honest 120 mph everyday easy.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
How about Hurricane?
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
Do they make a lower performance turbo for the apex?How about Hurricane?
ghost rider
Suspended
- Nov 13, 2013
- Muskoka, Ontario, Canada
- Rxwarrior
- Muskoka , Ontario
Don't kid yourself you get use to any hp level and then want more....go for it you will not regret more power.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I think they will make what ever you want. Dave is a good guy to deal with.
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
Hard to start out with a turbod apex for only second year driving? LolDon't kid yourself you get use to any hp level and then want more....go for it you will not regret more power.
youngsterx1
- Jan 3, 2005
- Manitoba
- Apex
I am aware Bender does not make kits anymore. I believe Justin from Full Power Performance was responsible for the development of the Bender Turbo Kits. This was in response to the post of FPP kits that are now being made. Just saying that I am happy with my kit.How about Hurricane?
I've spoke with Justin when installing my kit and found him to be a great person to talk with. He was very helpful with the questions I had for him.
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
Thanks will look into it.I am aware Bender does not make kits anymore. I believe Justin from Full Power Performance was responsible for the development of the Bender Turbo Kits. This was in response to the post of FPP kits that are now being made. Just saying that I am happy with my kit.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yes I bought an 06 Attak a while ago with the FPP2 stage turbo setup! Stage 1 is fast and also very good on fuel! Stage 2 is too much for trails and hard on fuel. Worry about other people trying this thing out on stage 2, stuff happens quick with this! Best part about this old set up is I can call Justin @ FPP and still get answers for my questions and all parts still available! And it was built by him but I purchased used from another! Beat that...
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
Thanks for the info, how do you know about stage one tho? You tried IT?Yes I bought an 06 Attak a while ago with the FPP2 stage turbo setup! Stage 1 is fast and also very good on fuel! Stage 2 is too much for trails and hard on fuel. Worry about other people trying this thing out on stage 2, stuff happens quick with this! Best part about this old set up is I can call Justin @ FPP and still get answers for my questions and all parts still available! And it was built by him but I purchased used from another! Beat that...
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
My set up is much like you will find on the FPP site. It has 2 stages, a toggle switch with dual position is how you go from stage 1 to stage 2. Stage 1 is 5lbs boost, while stage 2 is 10lbs of boost. Motor is stock so you need 91 octane for stage 1 and 100 octane for stage 2! Is that what you meant?
