DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
slp
SLP make some speed clips you can install were you have no clips. They work well, you'll gain 1-2 mph with them.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Just install these and all your troubles will disapear.................
www.denniskirk.com/jsp/search/search.js ... atId=30804
06vectorgt
I have just installed these anti-wear pads from SLP, I am hoping they do the trick.
http://startinglineproducts.com/catalog ... ductID=488
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
I have something for you guys to try. Elevate the rear of the sled and turn the track by hand. I just installed my anti wear pads and as I was rotating the track after installing a number of them it suddenly broke loose. I thought something broke, but what actually happens was the anti wear pads that I had installed made it up to the front of the curve in the hyfax. Boy what a difference :shock:
06vectorgt
I actually felt the difference in track/hyfax drag when installing them also!
- 7K
