Fuse location heated visor?
Silver4
Ottawa
Canada
2013 RST90D Venture 973 cc carbs
2013 RS Venture. No voltage at end of heated visor cord.
All fuses below test good.
1) No fuse is labeled "heated visor" or Aux besides aux DC jack. which fuse is for the heated visor?
2) Would this sled have one OEM when new or did previous owner likely have installed this??
Many thanks!
Seems to me I will likely have to run a new cable ...?
Its probably an add on power cord thats directly wired to the battery. Cable broke or some have an inline fuse. Follow the wires!!!
If it on the left side under handlebar, it's factory.
The fuse labeled S/H is the "shield heated" fuse. 3A.
Your cord could be bad, or shield itself died??
carbed model?
