mshabaz
- Aug 16, 2006
i've been reading alot of post on handlebar risers recently. i'm 6'3 and had a rox 2in riser on my apex. needed taller so bought the rox 5in and knew i would need longer cables. some people were commenting on buying cable extensions and so forth. all you need to buy is the mountain throttle cable and brake line. they fit like a dream and are as cheap if not cheaper than the aftermarket extension cables. the less moving parts the better. another fyi...the brake line will actually fit and work...but it was a little tight. so just buy a new one and be safe. parking brake cable still fit.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Hey thanks! I put the moutain risor on mine with stock cables just rerouted but I too want taller yet. ANother 2" would be ideal now I know what it will take. Thanks for the post!
