mckay_06
- Mar 23, 2011
- Saskatoon, SK
- 2014 Yamaha Viper XTX
Hopefully, any info will help. Ordered a new sender today so hope it was that as it is an easy enough fix.
sleddheadd
I replaced the entire gas guage assembly. It was east! 4 screws and a plug. Problem solved! Parts 9 and 10 on the gas tank diagram. I got the entire unit.dexter said:maybe sledhead will chime in and tell us what he replaced specifically.
dexter
thanks sledhead... I will check this out. did you notice a difference in them? float sticking?
mckay_06
- Mar 23, 2011
- Saskatoon, SK
Perfect thats what I ordered and hope it works for my problem.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Here is a thought.....The auto industry for several years now has been having a simillar issue. After research and testing of the removed fuel senders they have concluded that high sulfer content in modern fuels is causing concerns with the resistor card. All the automotive manufactures have released bullitens to add a can of Chevron Techron Plus into your full tank of fuel and it cleans the resistor card on the sender and the problem goes away. If this is not done and you just replace the sending unit, you end up having the same concern. So that being said since my sled is having this issue, I will add a can of Techron Plus this weekend (we got 14" of snow yesterday) and see if my concern goes away.
dexter
techron is supposed to be good stuff. I have a bottle ready to put through the wifes yukon.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Make sure it is the "plus" FYI I do not own Chevron stockdexter said:techron is supposed to be good stuff. I have a bottle ready to put through the wifes yukon.
dexter
havent seen the plus... where did you pick it up?
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Any parts store should carry it, NAPA, AutoZone, Pep boys etc.dexter said:havent seen the plus... where did you pick it up?
mckay_06
- Mar 23, 2011
- Saskatoon, SK
thanks for the info
sleddheadd
Yes, I noticed, the gas guage works fine now, just like it used to. Nothing is sticking.dexter said:thanks sledhead... I will check this out. did you notice a difference in them? float sticking?
mckay_06
- Mar 23, 2011
- Saskatoon, SK
put the new fuel sender in yesterday and seems to work. Went for a little ride and the gauge only went down one bar, not all ha ha.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
How much for a sending unit?
mckay_06
- Mar 23, 2011
- Saskatoon, SK
Costed me about $100, takes a total of 1 minute to change it out.
