Snakebit
Off of a fuelie Venture I believe.Snakebite is that a Vector gage cluster you have mounted on you Nytro? Is there a link showing how to do that?
Just made a bracket for the gauges, a backing plate for behind the dash panel, and a RAM mount.
A side benefit is with this mount, you can angle the gauges out or up.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
Does it plug directly into the Nytro wiring harness? If so does it display everything correctly including the engine warning codes, warning lights, high/low beams, rpm, speed etc?
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
Nice up-grade snakebit, I always liked my gauges on the Apex's much more than the Nytro. If this didn't cost so much I would have tried to change over to this also. I think I have heard guys say you have to run a seperate hot wire to the gauge to make the clock work, is that right?
johnelway
yes perfectly if you take the right one.Does it plug directly into the Nytro wiring harness? If so does it display everything correctly including the engine warning codes, warning lights, high/low beams, rpm, speed etc?
The 2010 and newer EFI Vector gauge will plug right in and read correctly though. Even all the diagnostic functions will work as well!
The only wiring change required, is to add a B+ wire to the connector so that the clock will retain its memory.
Mills
- Dec 4, 2007
I smell a gage cluster upgrade coming up!!! Thanks for the info.
- 12K
