Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I know the trick to turn on the lights/gauge without starting the sled ....
have kill switch on, hold down thumb warmer, turn key on, wait 8 secs for everything to light up
I've done that routine a million times, works flawlessly - except recently. I've been prepping my sled for the seaon, and the trick doesn't seem to work any more. The sled starts and runs fine, but I can't get things to light up without starting the engine.
Any ideas?
Any ideas?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
gade-thrasher said:I know the trick to turn on the lights/gauge without starting the sled ....
Any ideas?
Never heard of this one before, what sled are you referring too?
Curious if it would work on my 08 Vector?
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
Yup it works. Funny to see a snowmobile in the dark with the lights on and not hear the motor running. Sometimes my Vector will not work but most of the time it works fine.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Maybe a weak battery?
Or did you install HID lights?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Sled is an '06 Nytro.
Battery has been on the trickle charger all summer long. The battery turns over the engine just as strong as day one. No HID light either.
The trick has worked a million times in the past. It puzzles me why after all of a sudden it doesn't work anymore.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
possible the thumb warmer switch has a little grime/corrosion from sitting???
Daranello
Suspended
VERY COOOL!!! Does this work on the FX NYTROs or Apex's. It sucks starting a sled for 10seconds just to be seen at night on the side of a trail
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Crewchief47 said:possible the thumb warmer switch has a little grime/corrosion from sitting???
Just went out to try that ... The thumb warmer goes up/down just like it should when the sled is running.
Daranello said:VERY COOOL!!! Does this work on the FX NYTROs or Apex's. It sucks starting a sled for 10seconds just to be seen at night on the side of a trail
I believe it works on the carb 3 cylinders only.I have never tried it on my fx nytro or the efi vectors though.It does not work on the apex.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
You mention the kill switch is on? Shouldn't it be in the up position?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Grimm said:You mention the kill switch is on? Shouldn't it be in the up position?
Yes - it is in the UP position ... meaning turned on.
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I fixed it this weekend. I started by trying to troubleshoot the relay. The connections all looked good (no corrosion). But I put some dielectric grease on anyway, and now it all seems to work fine.
VectorLTX2012
When you have the lights on and you want to turn them off how does that work?
Chester
Gone Blue
- Oct 11, 2006
- Howell, Michigan
gade-thrasher said:I fixed it this weekend. I started by trying to troubleshoot the relay. The connections all looked good (no corrosion). But I put some dielectric grease on anyway, and now it all seems to work fine.
That is good to hear you fixed it. Thanks for your thread as I didnt know about this trick and tried it out on my RS Rage. I have less miles on my sled than I thought
