mbw919
Has anyone used these gauntlets SMA-MUFHK-00-00 with these mirrors SMA-8FTHB-MR-00 installed? I already have the mirrors and my cheap gauntlets don't fit well with the mirror mounts.
IA Rider
- Oct 12, 2009
- Floyd County, IA
- 2017 Ski Doo Enduro 1200
I have set of Power Madd gauntlets that are made to fit over the Power Madd hand guards mounted on my Nytro with the Yamaha handgards and those same mirrors. I unscrewed the mirrors from the plastic mount and removed the locking nut from the mirror then made a hole in the gauntlet with an awl and pushed the mirror through the hole and reattached them. They don't look bad and work well. I leave them on all of the time the mirrors have to be removed to take them off so they are not quick tach.
jimo368
I have those hand gaurds on my Vector and they work well. I was using the Ski doo windshield mount mirrors but had to take them off because they were making contact. I couldnt see out of them anyway but would also like to know if those mirrors would work with them.
IA Rider
- Oct 12, 2009
- Floyd County, IA
If the hand gaurds are the same as the Nytro the mirror mount bolts to the hand gaurd. The mirror kit comes with longer bolts and nuts to install them. The mirrors work very well. If you would like to see pictures I will try to post some tonight.
brad81987
- Jan 3, 2005
- Neenah, WI
- www.johnstoncomputerservice.com
IA Rider said:I have set of Power Madd gauntlets that are made to fit over the Power Madd hand guards mounted on my Nytro with the Yamaha handgards and those same mirrors. I unscrewed the mirrors from the plastic mount and removed the locking nut from the mirror then made a hole in the gauntlet with an awl and pushed the mirror through the hole and reattached them. They don't look bad and work well. I leave them on all of the time the mirrors have to be removed to take them off so they are not quick tach.
IA Rider- would it be possible for you to post a picture of your setup? I'd like to do the same sort of thing on my Attak. I have the Yamaha handlebar mount mirror kit and an extra set of PowerMadd handgaurds and would like to add some sort of gauntlet.
70superbee
I use the powermadd hand guards with the mirrors on the end of them. I also used there universal mount system that they came out with last year,it moves the hand guard out a little. Then I got a pair of skidoo gauntlets that fit in between the handle bars and the hand guards works great.
Richie R
Richie R
cat hunter
70superbee said:I use the powermadd hand guards with the mirrors on the end of them. I also used there universal mount system that they came out with last year,it moves the hand guard out a little. Then I got a pair of skidoo gauntlets that fit in between the handle bars and the hand guards works great. I use the powermadds with mirrors also and would like to add gauntlets if you could post some pictures that would be great!!!![]()
Richie R
IA Rider
- Oct 12, 2009
- Floyd County, IA
70superbee
Here are some pics. Of what I have.
http://s203.photobucket.com/albums/aa25 ... 0_0016.jpg
cat hunter
Those are what i'm looking for but if I could only get them without the Ski-doo logo!!!70superbee said:Here are some pics. Of what I have.
70superbee
Ski doo makes them in all black with no logo on them. Those are my wifes as she rides a renagade.
cat hunter
70superbee said:Ski doo makes them in all black with no logo on them. Those are my wifes as she rides a renagade.
cat hunter
Do the gauntlets interfere with the brake handle Superbee???
70superbee
No they do not. Even though I have the yamaheater installed I leave them on all the time. My hands just seem to get cold without them.
cat hunter
I'll go and check them out !!! thanks SB
