Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
RX1 with 10 lbs. 144"x2". I'm keeping my 38 tooth bottom gear. Do I want 22 or 23 on the top?
Click on my sig and use the gear speed calculator. Are you using a 21 top now?
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
No. stock 24. Forgot to put 8 tooth drivers.
TWIN TURBO
- Aug 30, 2005
- Chicago IL.
- www.powerbygns.com
Gear for the MPH you want to run or you think you can run in a given distance. Like sled Dog said use the MPH calculator.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
I run a 144x1.5 track, I run 25/28 and 9T drivers. Well I do mostly trail and lake racing. I even climp the steep stuff with it. Our snow is blown hard on the mountain and I'm able to keep the speed up on a climb.
With the 8T drivers I'll say keep it. Make sure you have enough weigh in the primary to grip the belt properly.
Remi Chiasson
- Sep 8, 2016
- nb
- 2011 apex xtx stage 2 mcx
hi rxrider!!! i have a 2011 apex xtx with a 144 1-1.5 track 9 tooth driver and a 290hp mcx. what gear do you recomand me for mostly trail and and very little lake race and off trail!!! thanks in advance
