Psi do you run?
I have Replaced injectors, fuel pump and regulator. Lowered ignition in the brain performed by MPI.
I ca try ur setup or tip?
Mine is only running at 6lbs.. it runs really well but only on the GEMS, I dont have a PCV plugged in. You can try my settings but leave the read mode at yours.
If it still runs like crap and stutters, I can sell you a autotune and just run the PCV with a Map from Ulmer.
unlited
- Apr 19, 2015
- Setermoen
- Norway
- Nytro MTX 163" 240 Turbo 2010
Nytro MTX 153" 190 Turbo 2013
Nytro MTX 153" Supercharged 240 hp 2012.
I have autotune and pcv v but i dont have a map, do you have a map? I need a map and i ulmer dont answer
https://ty4stroke.com/threads/new-map-s-c-800feet-9psi-of-boost.70700/
Contact Lakercr in that thread and see if he has a map for you or you keep trying to get Ulmer.
unlited
- Apr 19, 2015
- Setermoen
- Norway
Do you have a map i can get? Okey thx
Do you have a map i can get? Okey thx![]()
I dont have any Maps for a SC Nytro.. I was trying to help you tune yours with the GEMS.
unlited
- Apr 19, 2015
- Setermoen
- Norway
Yes i will try your gems setup. I hope it work!
I will also try and get you a PCV map for 6 lbs but you will have to tweak that for WOT at 10 lbs or turn on the autotune and make adjustment. Once you get the PCV map the gems will need to be unplugged.
unlited
- Apr 19, 2015
- Setermoen
- Norway
thanks. Yes, I get maps for 6 psi so I can auto tune and fix WOT. then I unplug the gems box when I connect to PCV
unlited
- Apr 19, 2015
- Setermoen
- Norway
"if i get a map"thanks. Yes, I get maps for 6 psi so I can auto tune and fix WOT. then I unplug the gems box when I connect to PCV
unlited
- Apr 19, 2015
- Setermoen
- Norway
Thx, i will try, is it 6psi boost map? Ulemer has to 9 & 11 psi map but i dont get it, i have send him a email
This is a 6 lb map.. u can compare if you ever get one.
- 25K
