GEMS Programming
Essarex
Canton, Michigan
Is there a way to install a map without the engine running?
I must have inadvertantly altered a setting(s) while I was tuning last night with my wide band, and the motor now will not idle without a lot of throttle adjusting. So it is almost impossible to man the throttle while trying to input mode settings.
Thanks for looking.
Jim
no, the box doesnt get power unless the sled is on... get a helper.. makes it a lot easier. and i honestly dont think the box setting should adjust the idle ability... i would check other things first. most of the dobeck(gems, attitude, etc) boxes dont adjust fuel at idle.
Thanks for the replies guys.
What I had to do was to wait for a completely cool engine so that it would fast idle long enough for me to get thru all the modes. I found that the GEMS is a little finiicky and sometines it will blow past a mode or two, and then you can accidently change the wrong range. With a little extra cae, I was able to get her dialed back in. It now purrs like a kitten.
Jim
