kuvasz
Does anyone have a good starting point for the gems settings for 1000ft elevation? i'd like to see 12.5-13.5 when driving normally and i'd like too see 11.0-12.0 when WOT. when i get the sled dialed in at WOT would i only adjust the main jet or the boost as well?
mmaman207
- Aug 18, 2010
- Maine
- 07 Attak Stage 1 MPI , 06 Apex Mtn Boondocker Race Gas Turbo.
What is it for a sled??
Stage 1 MPI??
Stage 1 MPI??
machzrobbie
kuvasz said:Does anyone have a good starting point for the gems settings for 1000ft elevation? i'd like to see 12.5-13.5 when driving normally and i'd like too see 11.0-12.0 when WOT. when i get the sled dialed in at WOT would i only adjust the main jet or the boost as well?
What boost you running?? I have numbers but they are with a msd fuel pump
kuvasz
sorry guys, i forgot about that info. it's an 08 apex with a stage 1 mpi and i'm running 10lbs of boost. stock fuel pump for now, unless i find it can't keep up.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
See my signature. Same set up as you.
