LazyBastard
If its new then the engine is still not broken in. They're extremely tight when new and can sometimes react a little funny (bogging, backfiring, etc.) It also has to be warmed up real well before it will run right.
A bog can come from more than just the carbs. It can also come from too tight of an engine, and/or incorrectly set clutching. Since you're in NY, I have to assume that you're trying to drive it on the dirt (not recommended). That clutching is not set for dirt, it probably would engage too low. Add that to the tight new engine, and you have yourself a bog.
Blue shadow
You can also check your throttle override system.
- Sauk Prairie, WI
- www.ty4stroke.com
Tighten your secondary if your running dirt...BBY
Silver
Make sure you didn't lose any of the little black o-rings when you were changing springs.(carbs)I have a bog and also lost one o-ring.OPPs
I thought I was being very careful.
- Sauk Prairie, WI
- www.ty4stroke.com
Good point silver...BBY
A bog usually is caused by a lean condition. The screw is a fuel screw and turning it in will worsen the condition. Try 2 1/2 turns out.
Thanks for the suggestions guys, they give me some different things to check.
