bigdave
- Dec 18, 2003
- sylvan lake, Michigan
- 14 Viper LTX SE, 14 Viper RTX SE , 08 FX Nytro , 07 FX Phazer, SOON 2017 Sidewinder LTX LE Blue
So I put on 350miles this weekend the sled rips (of course I did not really mash it) till after 250miles but after that I have seen 102 on the dream meter at just over 9000 rpm (I think it is over revin ??) I have noticed the the sled vibrates much more then my 03 RX1 is this normal or should I be concerned ?? also I hear the primary clanking a bunch and I think the secondary is wineing even on the gas and then have heavy backshift noise (maybe I am just nuts !!!) kind of concern !
then I found what might be a big problem but am afraid to take it apart due to warranty yesterday I found that the chain tensioner had backed off but not out only reason I even relived this is that the sled started to really rummble so I finger tightened it with an added 1/4 turn with a wrench and it seemed to get rid of some of the rummble but now notice the rummble when braking
STD FX nytro all stock with 144 studs
Please help me I think I am going crazy I might just be over anaylizing this thing !!
thanks Dave
thanks Dave
Yellowknife
wow that's quite a list you got there.
Loose chain tension will cause some vibration, so will loose track tension.
Speedo's are 6% out.
9000rpm aint' bad...8800 is ideal but it all depends on what your riding on and what your load is.
Not sure about clanking in primary, don't sound normal. Maybe it's nothing though...if everything looks fine visually, just ride.
Backshift noise is fine...
That's my two cents.
grader
back off your chain tension. tighten it finger tight and then loosen it about 1/4 turn and lock the nut.
cameljockey
my primary is noisy also but another ty member seems to think it just the weight and is normal. never tighten your chain adjuster with a wrench, finger tight and back off 1/4 is correct. i think we here more clutch noise and backshift because of the venting in the side panels. my sled rocks and with a little more suspension tuning it will be the funnest sled to date.
The chaintensioner did the same thing on mine and two other RTXs the other day.
bigdave
- Dec 18, 2003
concerns
Thanks Guys I think I might take it in just to make sure the chain has no problems not really sure how long I rode with it loose (maybe only 10 15 miles) plus when you come to a stop the brake feel a bit shakey not smooth
I was thinking it was the track making most of the vibration I have adjusted it twice in the 300 miles or so
thanks again GUYS
thanks again GUYS
I noticed my cluch making more noise at 1000 miles blew belt at 350 and 1050 miles both at 95 mph
mark
nytrochic said:I noticed my cluch making more noise at 1000 miles blew belt at 350 and 1050 miles both at 95 mph
You're on your 3rd belt already?
yes and soon as I jump into fresh powder sled hits 9100 and bounces off rev limiter and I have 2 let off and feather throttle and have been breaking in new belts
Yellowknife
alignment has to be off right? I've got nearly 3000 km's on my belt.
Kråkan
I have never blown a DN belt. If not rinding in EXTREME conditions there must be something wrong to blow 2 of them in 1000 miles.....
Yamahnator
Yellowknife said:wow that's quite a list you got there.
I wonder if the RTX speedo's are off the same amount as the MTX speedos. Any idea?
Yellowknife
Not sure, but my Phazer was out that much too.
