JP10
I got my phazer stuck in a 3 foot deep bog and partially submerged, water in over clutch. She never shut off but I shut her off anyway. After 4 hours we finallly got it out by rolling it over 360 degrees and put the handlebars and gauge pod under water.
She started perfect and once the clutch dried she was perfect. Is there anything I should Check.
Thank you
JP
Thank you
JP
Chaincase and probably change the oil and maybe even gas.Grease suspension and Ideally the bogies also.That must have really sucked!Any pics?
couch
Sucks when the snow comes before the frost. Most of the gullies here are still open / running but the ponds are starting to solid up.
Glad to hear that it started after being rolled 360 in the bog.
JP10
No no pics.... I already cleaned the airbox, there's some water in the headlight, Do you have to take the headlight off completely to slip the lense off?
And does anyone know if you can take the gauge pod apart... There some bog in that or will it just clear up after it fogs up sometime?
thank you
thank you
- 33K
- 6K
