GPS Mount
Ram mounted on the front of the riser.
I put a 5" display Lowrance in a tank map holder. This is mounted flush in the tank bag. Easy to read and operate. This is mounted on my 09 Nytro
I have a nicely placed ram mount that sits left of the speedo.. Easy on and off......... Should be sweeeeeeeeeeeeeeeeeeet.. Now I need snow to check it out.. MM.:(
Ya mine is ram mounted also, but on the right of speedo as shown because I put in a temp gauge on the left.
I mounted mine in the middle of the handlebars in place of the crash pad. I used a bike water bottle mount on the handbar.
Here is what I've done with mine.... Removed the gauge pod, and added the Ram (handlebar) mount, with a shaped aluminum backing plate in behind for strength.
Viper 1.0 Garmin Montana mounted to riser front with RAM mount.
