GPS which one
Prob aren't many people who Sled AND use a H20c. If you can see the trail maps on the device and your position you will have most of the functionality used by sledders with a GPSr. Turn by turn routing on snowmobile trails would be/is very taxing on a somewhat meager processor.
Also you might post on a site with a larger user base - here you are constrained to mostly guys on a Yamaha - reducing your subset even more. Try the HCS GPS forum although its not that active either relative to JUGGS and my-sled-is-better-than-yours threads.
Thanks for the feedback! I think that I will try it with a temporary mounting method first to see if I like it before investing in a Ram mount. If I do not like it I can buy something better for the sled and keep using the Lowrance H2Oc just for my boat.
As for mounts
RAM has the most options
I find what I want on RAM's site and order everything from GPSCity.
Other than the part the unit actually sits in, the cradle, the remaining parts, the ball and arms, are universal. So if you get another GPSr, you likely will only need an inexpensive cradle to adapt it to your existing RAM hardware.
Thanks for the additional info on the mounting! I am excited to try a GPS on the trail for the very first time. I will be testing this set-up in the Mercer, WI area next weekend!
60CSX type are nice in functions but the screen is small. I have a 276C rugged,waterproof and can do lot's of stuff with tracks,saved or otherwise that any Nuvi can't do. I have it mounted on the riser with a Ram system..
I don't have the color unit, just the Lowarance H2O. It's not turn-by-turn, but you don't use that on a sled anyway. The screen seems small, but it works in -15f without issue. It's waterproof and the ram mount is more than solid enough to mount on the handlebars.
I have found that the redpine maps are accurate enough that I can see hairpins coming up on the map quicker than in the snow dust sometimes. It's a great tool and appreciated. If I had to do it all over, I may look for something with a bigger screen, but I had the H2O and planned on using it.
I did download the free Polaris SnowTrails app for my iphone, but my waterproof iphone case just was not solid enough to mount on the sled. That and the iphone does not like the cold. It's a good reference to pull out of the pocket when needed.
Good luck!
Good luck!
I have only tried it out at my house so far but with few snowmobile trails nearby and so many roads on the screen it was really hard to decipher. I will be testing it on the trails around Mercer, WI this weekend. I am hoping that when I get away from the cities that it will be easier to see the trails.
If you (or anyone else) have any tips on certain settings in the Lowrance menu's to make it work better for this application please PM me or call me at 612-868-7686.
Thanks,
Dave
Redpine gave the best tip. On the lowrance, you can go into the trail gps settings and shut off many of the items that you don't need to see.
By default, mine were shut off, so all I saw was the trail. That served little purpose until we turned the roads, railroads and towns back on. Then the relation of trail to road or trail to town was perfect.
Then you just pick a zoom level that gives you the amount of detail you need in a timely manner.
For example, if I want to see hairpins coming up, then I am over zoomed in. If I want to get a general idea of where the next road or town is while going cross country, I may zoom out.
I had mine setup with a medium zoom and showing drainage ditches. We were flying across fields and would come up on drainage ditches at speed in flat light. That can be dangerous, so the GPS helped us there.
Good luck!
We have an H2Oc with a ram mount. I only use it to mark our trails in case we have to back track. In the summer it goes in the boat.
60csx- hardwired -redpinemapping(free version)-topomap
Thanks guys!
I already have a Ram mount with a suction cup for my Lowrance H2Oc that I use in my boat. Can I just replace the suction cup part with a handlebar mount and re-use the rest of the parts?
