NewfiePhazermtx
- Mar 16, 2015
- Newfoundland
- 2008 Phazer mtx
I have a 2008 Phaser MTX the grip warmers and thumb warmers mot working correctly they work intermediately? anyone know what the problem might be?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Possibly a grounding issue, 07-09 Phazers had an update available to fix a ground block issue. Very possible that yours never had the update, all the ground wires should come together on the battery side near where you check the gear case lube.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
NewfiePhazermtx
- Mar 16, 2015
- Newfoundland
- 2008 Phazer mtx
What should i be looking for? Its could be a ground issue the warmers come on and off for short periodsPossibly a grounding issue, 07-09 Phazers had an update available to fix a ground block issue. Very possible that yours never had the update, all the ground wires should come together on the battery side near where you check the gear case lube.
NewfiePhazermtx
- Mar 16, 2015
- Newfoundland
- 2008 Phazer mtx
There is good heat when they come on, but they only come on for short periods at a time and could go days before they come on. No codesAre there any codes showing up? If the heat is insufficient, there is an update specifically for the '08 MTX.
- 13K
