Growls, lacks power 6000-8000 RPM?
Roger
Osgoode Ontario Canada
Canada
2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
Hi All
My 2007 RS Venture, 17000km, 10500 miles sled is acting up.
There seems to be a growl and slight vibration between 6000-8000 RPM. It also lacks power in that range. It starts and runs fine.
I've cleaned the primary as best I can without splitting the clutch. My neighbour, a Polaris Mechanic, thinks the primary clutch is fine. I've cleaned the secondary and changed the buttons. I changed the exhaust o-rings, because they were literally gone. I tried a different belt also. I adjusted the track tension, and checked the chaincase tension.
The lack of power, and growl/vibration is still there.
I'm going out right now to check the Jack shaft and Drive shaft bearings for play. I'm then going to install a brand new belt and test drive it.
Any suggestions to help me nail this problem down?
Roger
The carbs were cleaned at the start of the season, and I never checked the plugs. I'll do that right now, as I just came in to get dressed. The bearings don't have any play in them.
It's been doing this for a couple of tanks of gas.
I checked the plugs, and my right plug was wet before I started it tonight. Could it be the jet sticking a bit, with a bit of flooding happening at that rpm?
I'm going to try to clean them again.
Thanks for now.
Hi Apex and shed
I cleaned the carb again, with the wet plug. Took it for a test drive and all seemed well. I'm going for a good run Sat./Sun. and will report if it's still running well Sunday night.
I run Yamaha belts as the others don't last for me.
Everything ran perfect this weekend. 350k.m. and all is well.
My week vacation starts now, and it's off towards Cochrane from home.
2500km's in 8 days is always a good trip.
