05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
i have a 2005 vector that i cant seem to figure out why it wont go over about 60 mph. I've replaced the donuts, cleaned the carbs multiple times, and replaced the drive belt. It was running great up until the donuts went bad. now it doesn't seem to have any power top end. It idles good, and seems to have the power when on a jack stand, but once put under load it wont do much over 60. Does anyone have some insight? or know what might be the issue?
when where the clutches last cleaned/serviced?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Torn carb boots?
theCATman
- Feb 19, 2007
- WI
- Yamaha
If it ran fine with bad donuts, then my best internet diagnosis is a partially blocked exhaust from something and now with a sealed exhaust it can't breathe.
Did you have it stored somewhere that mice could have built an apartment complex in the muffler?
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
to my knowledge they have never been serviced.when where the clutches last cleaned/serviced?
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
Torn carb boots?
Id have to double check that, the carbs have been off so many times i hope i would have noticed if this were the case.
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
it ran horribly with the bad doughnut gaskets. im wondering if a fouled plug would make it run this bad? its almost like its only running off two cylinders. And as far as the exhaust goes. there aren't to may places a mouse cant go,so the there is a change,but it seems to be getting a good flow through them.
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
would a fouled plug cause this issue?
Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, Elevate, lots of mods
Yes that could be the case, so go ahead and check them. Make sure they're the right ones too. How long since last check?would a fouled plug cause this issue?
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
late last winter/ early spring. It was shortly after that it was stored for the summer.Yes that could be the case, so go ahead and check them. Make sure they're the right ones too. How long since last check?
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Yes , check the carb boots and your air box. Two years ago my daughter went off trail and a branch poked a hole in the air box . It would start and idle fine but I could only go 50 mph . Once I discovered the hole and installed a new box it ran perfect! Check the rest of the things mentioned in other post . But double check the boots and air box
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
The engine isn't winding out so, that leads me to believe that its not the clutches... right?when where the clutches last cleaned/serviced?
DGZRT
- Feb 23, 2006
I have had a broken primary spring and it limited my speed . You can do a visual inspection of both clutches very quickly . Check springs , and secondary clutch buttons , check belt , then support the rear safely and Rev up the motor to make sure clutches are working properly . If air box is installed correctly and carb boots and it still doesn't work then change the plugs and see if that helps. If possible check for spark when changing the plugs . If its none of those then its back to the carbs .The engine isn't winding out so, that leads me to believe that its not the clutches... right?
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
alright, ill be at the shop all day tomorrow hopefully i can locate the problem. thanks for the help. ill let you guys know how it goesI have had a broken primary spring and it limited my speed . You can do a visual inspection of both clutches very quickly . Check springs , and secondary clutch buttons , check belt , then support the rear safely and Rev up the motor to make sure clutches are working properly . If air box is installed correctly and carb boots and it still doesn't work then change the plugs and see if that helps. If possible check for spark when changing the plugs . If its none of those then its back to the carbs .
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
It appears the air box has been repaired with sealant of some sort. There is also some visible around the the carb boots on the air filter side. Is this factory or did the previous owner do this? Also I was able to spray starting fluid around that same area and it made the engine idle go up so clearly it’s getting by, just don’t know if it’s enough to make a significant impact..?
