Josh_D
Got an 05 vector with a Simmons CPR kit. Has a gt2554 turbo that now leaks oil out both ends of compressor housing, so I've spent a good while on google trying to find a rebuild kit with no luck. Anyone know how sells kits or center cartridges? If I can't find a replace would 2560 or 2860 be better? Thanks
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
Pretty sure I have a good (used) 2554 center section on the shelf. I'll double check and let you know.
sledracer
I purchased a new center rotating section from Justin at Full Power Perf. I believe Garrett controls who can sell them to be sure of the quality.
Tyler
Tyler
Josh_D
Thanks for tips gents
Josh_D
Just curious tho, anyone have a 2560? I just compared maps of the 2554 vs the 2560 and i like the fact that the 2560 moves the same amount of air at less wheel rpm and supports more hp and also has a broader efficiency island. Just wondering if maybe i should upgrade to this charger, thoughts?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I have 2854r turbos on hand. These will work good on a vector up to 14 lbs. Will be a direct replacement as well.
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
Just following up on this. I do have a very good (used) CRHA from a 2554 available. Garrett tag is 471171-3, made in Japan.
Let me know if you're interested.
