JDMCRX
- Dec 13, 2005
- OTTAWA, ONTARIO CANDADA
- www.jbauto.ca
Just curious as to what A/F you guys are seeing on Cruising and WOT ?
NA only
NA only
RTX Meirda
It bounces around a lot.
Most of the time, I see 12.4 to 12.8
SledFreak
- Feb 7, 2005
- Ontario. Canada
What about @idle to 1/4 throttle?
ptt
Guest
air/fuel
I assume you are putting one on your RX-1?
This is what I tune to:
Idle: 13-13.5
Mid range cruising: 12.9-13.6
Top end: 12.4
The apex is set up to run around 12.3 on reg. fuel.
Hope this helps
ptt
Idle: 13-13.5
Top end: 12.4
Hope this helps
ptt
RTX Meirda
SledFreak said:What about @idle to 1/4 throttle?
Idle....11.8 or so.
1/4 throdle...?
I never ride that slow.....I always pulse the throdle as well, so I never see th same numbers very long.
- 9K
