Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
FYI, have been doing lots of adjusting on compresion and rebound and have found the rebound damper adjuster is extremely stiff and when you zero out the setting to make an adjustment and you think you are at zero when in fact you are not. I got fooled twice now and had my settings 5 clicks different from L to R and that makes it a bit goofy in the chop !
Interesting to hear if anyone else has a similar issue ?
Fasttoys
i have the same problem on my right front rebound adjuster very hard to turn feels like its gonna break off. might have to see if they can due something about that under my warranty.
Reaper
- Nov 10, 2005
Interesting, it is also my right front shock (as you sit on the sled). I used a philips screwdriver and my fingers to coax it past the stiff spot, shot in some WD40, and worked it back and forth several times and seems to have looseded up now.
Fasttoys
hmm yep same thing. ill have to try that WD40 trick maybe it will work
Reaper
- Nov 10, 2005
The adjuster is held on by a phillips screw, I used a screwdriver and my fingers to get enough leverage to get it moving back and forth with more ease.
BLUEBALLER
- Jan 29, 2005
I noticed this yesterday as well, left front shock, rebound clicker. Hard to turn, and then after fiddling with it all afternoon, it seemed to keep on turning without coming to an endpoint. I'll check it with a phillips and some WD to make sure it's not hooped.
Also, are you counting more clicks then there are supposed to be? I'm pretty sure it's 20 clicks, but I counted 22 on one side & 26 on the other. WTF!!
Reaper
- Nov 10, 2005
20 is max setting but it will go farther, I can get 24-25 clicks out
- 15K
