hard starting ...any idea`s
piped bravo
Porcupine.
Buddy has 03 RX rear mount bender....sled works very well, easy cold sart...even if you run it for a few miles 10 minuts give or take ..it still starts well....but if you go 30 -40 miles and shut it down ...wait 10 minuts and go to start againg ...it turns over for 2 minuts before it fires ...and when it does it sounds flooded and a shot of black smoke fires out the exaust....
and when he stops he always lets it idle for a few before shuting it down to let the turbo cool it self off.....any idea`s...thks
Does he hold the throttle open a small amount while trying to start, when engine is hot?
Should do the trick.
yep.....its the only way to get it started...just that starter keeps turning for a very long time before it starts to gargle...
Does he have a water shut off for the heated carbs? I only leave mine open a very small amount to keep the carbs from icing.
yes when i push on the tubes collant leaks out!!!
can i shut the carbs right off? looks like real quick fix
if i can run with out heated carbs... and turn them on when its real cooled
Piped Bravo, You might also consider sending a PM to JonnyRocket (Jon), spray25 (Ray), or Silver Streak (Ryan) explain what is going on with the sled. Everyone of these three guys have at least 3 yrs of tunning a Bender Turbo RX-1. I know for sure that Jon has experienced similar problems starting the sled (after it sits a while) once the engine is heated up to operating temps.
Your buddy might also need to adjust the floats to 17mm (If I remember correctly) in addition to a coolant block valve for the carbs. Yamaha specs say between 13-15mm but, this was a fix that Ryan swears will cure flooding issues while still giving the T-RX-1 enough fuel to run without any ill behaviors.
Jim.
You should try to post the result so if someone was to search this topic one day they will find the answer. :)
