2014 viper
- Aug 10, 2015
- killarney
- 2014 Yamaha viper xtx
2014 Yamaha viper it has osp muffler it hot starting problem it has all ecm updates
You can either take it back to the dealer or add a PCV, I added more fuel off 0% throttle and it fixed it.
larrypolaris
After my starter kickback cal update. My sled usually takes at least two crank tries to start.
This weekend I went to start my sled in my headed shop and it took three crank tries to start. A disappointing pain in the ....
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
man am i ever glad i left mine after the first update in 15.....let the pump cycle and it starts hot or cold. Just because its an update doesnt mean its the step in the right direction
First of all Define Hot Start Issue.2014 Yamaha viper it has osp muffler it hot starting problem it has all ecm updates
I have not heard this complaint since the 15 update. Be specific. Could just be a bad battery or dirty connections,fouled plugs etc. Need info like is it turning over quickly? Is it idling properly and at what rpm when it is running. How often does it do this?
2014 viper
- Aug 10, 2015
- killarney
It has a new batteryFirst of all Define Hot Start Issue.
2014 viper
- Aug 10, 2015
- killarney
It
it idles good could it be running lean because of the muffler ,connection are good ,does not do it all the timeIt has a new battery
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
Put an optimate 4 battery charger on that new battery for a few days if you can, but at least 24 hours and see if you see a difference. Just because it's new does not make it fully charged. 24 hours with a good battery charger is the minimum I would charge a new battery, and charging a few time through the riding season and off season will triple the life of your battery.It has a new battery
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
I run battery tenders on both mine all the time.Put an optimate 4 battery charger on that new battery for a few days if you can, but at least 24 hours and see if you see a difference. Just because it's new does not make it fully charged. 24 hours with a good battery charger is the minimum I would charge a new battery, and charging a few time through the riding season and off season will triple the life of your battery.
You still have not answered what it does when hot. Does it take two or 3 tries to start? Does it never start? Does it crank real slow? Had Friends little kid over other day and he sat on my sled and wanted me to start it. So I did. It started so fast it scared him into crying and he ran away! To him it has a starting problem.It
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
Cannondale27 is asking those questions because the answers to those questions will help him determine the likely cause of your problem. Once he narrows the cause down to a couple of options he can recommend a course of action. He is a staff member and Moderator because of his intimate knowledge of most aspects of this design and he is better able to help you than most other people on this site and Probably better than 95-99 percent of any other group or dealership could.It has a new battery
Please,let him help by answering his questions to the best of your ability.
Thanks Testmaster. Actually a video of it doing it is best. 2014 I really am not picking on you just need more info. Back in 13-14 when there were all kinds of issues with hot start majority had to just slightly touch throttle to get them to start. Once 15 flash came out the hot start problem went away. Exhaust has no effect on starting.
2014 viper
- Aug 10, 2015
- killarney
It cracks over fast it doesn't start you touch the throttle and it will startYou still have not answered what it does when hot. Does it take two or 3 tries to start? Does it never start? Does it crank real slow? Had Friends little kid over other day and he sat on my sled and wanted me to start it. So I did. It started so fast it scared him into crying and he ran away! To him it has a starting problem.
2014 viper
- Aug 10, 2015
- killarney
I have I video of it I can not load the video on here
Pm me your Vin # I want to be sure updates were done. Then I need you to go into diagnostic mode and check TPS #'sIt cracks over fast it doesn't start you touch the throttle and it will start
