Surestick
- Jan 19, 2015
- '07 Phazer Mountain Lite
Following. I have an 07 Phazer and having sorta same issue. Although mine will fire up perfect for about 10 seconds and then shut off. Fire up again and then you can crank it over endlessly and wont fire up again.
I've never experienced this myself. When it's really cold mine will sometimes start then die after a few seconds but on the second try it will start and run fine.
I've read other people here mention that if you shut the Phazer down before the cold temp warning light is off on the dash it can foul the plugs or flood the engine.
