dieselnick
Hi
I weight 160 pounds.
My settings on my phazer mtl are :
Softest setting for the 2 front shocks with the sway bar.
Hardest setting for the rear shock.
What should I do to get my sled easier to turn the skis?
What are the optimal suspension setting for a stock phazer mtl with an anti-bottoming kit ?
Granahan378
Stiffen up your front shocks instead of the pressure going to the skis its lost in the shock making it harder on you to turn.
Go up one hole on the limiter strap, made a good difference with mine.
dieselnick
I am from the dirtbike world and I never adjust a limiter strap before.
What is the limiter strap for ?
In the front of the skid there is a strap. Just take out the 2 10 mm bolts and tighten it up one hole, I did this and it steers much better.
Good luck
Good luck
rfabro
dieselnick said:I am from the dirtbike world and I never adjust a limiter strap before.
Rear end on dirt bike has only one point to place weight. The rear weel. Rear end of sled has two points: front and rear of skid. Limiter strap sucks up center shock, preventing it from fully extending. This takes weight off front of skid, placing more on skis and rear of skid.
