Has anyone cross referenced the OEM oil filter to different
mmollema
Lake Orion, MI
I was just wondering what ther brands people have used and also what other types of oil other than yamalube do you use. Is it best to just stick with the stock yamaha parts and oil. Thanks
I'm running Amsoil in my sled and my GF's skidoo 4 stroke and so far no problems, as far as the filter i just run the oem one
Unless your going to run the Roest skid plate stick to OEM due to the limited dimensions allowed by factory belly pan. In other words if you run an aftermarket filter and bump somthing right on the sweet spot, you run the chance of cooking your motor. Do a search on here!
BordnBill said:
I run Yamalube and K&N filter. K&N filter has that nice nut welded to the oil filter for easy on/off.
I also used the K&N filter, same size as oem. Off the top of my head I think it's kn-147 for a part number.
I use the napa version 1358
They are made by Wix, so you know they are not a pos filter
Here are some other options got from another site (snowandmud)
Yamaha - 5DM-13440-00-00
Media:
Height:
Outer Diam:
Max Flow:
Microns:
Relief Valve PSI:
Average Price: $17 - 21.00
____________________________________________
Fram - PH6017A
Media: Paper/synthetic fibers
Height: 2.92"
Outer Diam: 2.69"
Max Flow: ? GPM
Microns: ?
Relief Valve PSI:
Average Price: $9.00 - 12.50
_____________________________________________
Wix - 51358
Media: Paper
Height: 2.782"
Outer Diam: 2.685"
Max Flow: 8-10 GPM
Microns: 21
Relief Valve PSI: 8
Average Price: $10 - 14.00
Purolator - ML16817
Media: Paper
Height: 2.95"
Outer Diam: 2.57""
Max Flow: ? GPM
Microns: ?
Relif Valve PSI: 9-12
Average Price: $15.00, 2 pack on amazon for 10.54
K&N - KN-147
Media: Synthetic Filter Media
Height: 2.461"
Outer Diam: 2.807"
Max Flow: 8-10 GPM
Microns: 21
Relief Valve PSI: 15.37
Average Price: $14.00
