Removed User
nytro23 said:That was the initial driver behind doing it. It works real slick, and the extra brace you weld in is good for keeping the front end true.
This doesn't interfere when the shock is fully compressed??
Nytrosnox
- Aug 1, 2009
- Cleveland, WI
- 2013 Nytro XTX 2017 Sidewinder XTX
Has anyone ever cut it to remove it?
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
Yea i cut mine to remove it because the bolts where stuck. No problem.
Nytrosnox
- Aug 1, 2009
- Cleveland, WI
Ok cool. Where is a good place to cut?Yea i cut mine to remove it because the bolts where stuck. No problem.
yamahamm
- Oct 9, 2009
- Norway
i just cut it on one side so i could yank it out from the other side. I used a hacksaw with steel blade.
Nytrosnox
- Aug 1, 2009
- Cleveland, WI
Ok going to try that, thanks.i just cut it on one side so i could yank it out from the other side. I used a hacksaw with steel blade.
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Removed mine after two seasons using it. Like some others posted you will nee to use more air in your Fox shocks or higher spring rates in your coil spring shocks to compensate as removing the bar lowers your overall spring rates. I ride mostly high performance trail and the improvement in performance was noticeable immediately. Better ride quality, better turn in and less under-steer were the major improvements. I was able to remove mine with out cutting it but it takes some time and patience.
SnoBird888
So overall removing it will increase front end handling? Im tempted to just disconnect it to try this wnter however I will have the subframe out so prob easy to remove it then.
m.schuey7
- Feb 4, 2014
Yes, Much nicer and easier to ride on the trails and using stiffer front spring rates keeps the nose up and the travel longer which also contributes to a safer and more stable chassis.
NytroMisfit
- Feb 18, 2015
- Levant, Maine
- 2009 nytro xtx
Just took mine out and I bought float 2's this off season can't wait to try it
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
Do yourself a favor and just disconnect it and tape it back or just disconnect one side and try it. I took it out but did not cut it and I put it back in. As the front end really dives with it off. But to each there own
m.schuey7
- Feb 4, 2014
ZX4EVER,
If you don't increase your front spring rates it will definitely handle worse and be more dangerous
Nytrosnox
- Aug 1, 2009
- Cleveland, WI
Thanks guys. Have taken my sway bar completely out. Can't wait for snow.
zx4ever
- Apr 14, 2011
ZX4EVER,
Yes I realize that and I did pump up my fox floats to compensate. But in my opinion then it felt like pogo sticks. All I was trying to suggest was trying it before grinding or removing it all together as it is not that easy to access the bolts that hold it in.
Nytrosnox
- Aug 1, 2009
- Cleveland, WI
I don't have fox floats in front but have increased preload. If it is close, just gives me a reason to buy some.
- 6K
