Ski Whiz
I think I’m in for a head gasket job on my nytro. Any tips or suggestions to make the job easier?
What am I looking at for total hrs?
8 to 10 hrs, why you think you need a head gasket?
Ski Whiz
Ok, that gives me a ball park…8 to 10 hrs, why you think you need a head gasket?
Bubbles in coolant and when driven hard, it pushes coolant into reservoir and it does not draw back into rad as system cools.
Took a chance on this sled. Bought it cheap. After I had it home I noticed that someone has changed the water pump, and found welds on the heat exchanger. I’m thinking 2 potential situations when the previous owner may have overheated it. Now I’ll pay!
That stinks. You may have to be sure the head and block is flat.Ok, that gives me a ball park…
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I had the exact same symptoms on my RS Venture GT.
I don't know what the access to the top of the engine is like on the Nytro but yeah, it took me a couple of days. I also did the valve clearances as they were all off so needed a valve shim kit. The head surface was a little warped and I brought it flat using emery cloth on a plate glass. It has been working fine since.
Follow the manual for this. you'll need it. I had trouble dealing with the timing chain and tensioner.
RS Venture GT losing coolant
Related to RS Venture GT takes forever to warm up, now I find myself losing coolant. To recap, it had low coolant with no obvious leak, replaced the thermostat, refilled and it idles fine and gets up to temp and pressure. I also installed a temp gauge and bled the system of air (had it...
ty4stroke.com
Ski Whiz
I found other threads that discuss the possibility of doing the job in the sled.. no one actually confirms they have done it, they mostly speculate it could be done?!?
Perhaps since it’s my first (and hopefully last!) attempt at the job I should just get it on the bench?!
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
From what I have seen, the majority pull it out on the Nytro. Saw only one thread that said they did it with it in situ but had to tilt it to access the chain tensioner (I had to do this on my RS). That thread was never concluded to confirm it was done that way, probably the same one you saw.
Ski Whiz
Just curious, the service manual says use new valve cover gasket. Did u bother with that? I figured I could clean up old one and use some sealer on it.From what I have seen, the majority pull it out on the Nytro. Saw only one thread that said they did it with it in situ but had to tilt it to access the chain tensioner (I had to do this on my RS). That thread was never concluded to confirm it was done that way, probably the same one you saw.
I’m pretty cheap! Lol
