For you fellows that have been out & about at night.
How is your light projection, HIGH, LOW OR SATISFACTORY ?
Hiawatha
highbeams up in the trees and have not adjusted yet
Silverbullet
There are pretty good directions in the owners manual on how to adjust the headlights....But you would think a GOOD dealer would have taken care of it
![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
I noticed last night when I come into a corner and let off the gas, the throw you over the handlebars slow down process of these 4 strokes is so drastic that my lights shine straight down in front of the sled, I plan on adjusting them up a bit to see if it helps. Has anybody else noticed this?
LooseCannon
If your lights on low beam still seem high, there is a good chance the headlamp assembly is not on correctly. There are two little tabs under the lights that slide into the top mounting bracket for the headlamp assembly. If you don't get those two tabs in correctly the assembly sits on top of them and much higher leaving a bigger gap between the rubber boot under the light and the air box. Had the same problem and that was the fix.
![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
MADDOG24
Was riding the UP this week and noticed my low beams were very high. Hard to see with all the snow falling.
welterracer
I adjusted mine up..
on low they are too low... and at high they are too high...
They are definitly not as good as the Rx-1 head light.. I even tried 2 sets of bulbs.. made no difference!
welterracer said:I adjusted mine up..
Which bulbs have you tried, Did adjusting them up help? I put some silverstars in and like the light they throw, just need to fine tune the adjustments I think.
LooseCannon
jimmie d
Dealers are installing the pods wrong per above diagram.
Jim
Jim
LooseCannon
greenmachine said:Dealers are installing the pods wrong per above diagram.
Jim
Right On!
welterracer
I had silver stars first... went back to the stock bulbs.. they are brighter.. but still not as good as the RX-1.... (Rx had a better design)
leaddog
Same problem as welterracer. On low they are too low... and at high they are too high... Not real bad. I can live with it. (silver stars)
Starry Knight
I swapped mine out for SilverStars. The alignment seem s perfect, before and after the change.
I find the SilverStars MUCH brighter, and they have a nice cool color too.
