I have 08 Nitro MTX! My head light , tail light, hi beam indicator, brake light will not work. All the fuses are good. Any suggestions on what the problem could be? relay somewhere? Thanks
My 08 manual says that the Load control relay is the front most relay. This relay powers the Signal, Headlight and Aux DC jack portion of the fuse block.
You said the fuses are good but did you probe them with a test light to see if you have power there? If your sled sits outside or has lots of snow under the hood, try warming this relay up.
